Author Topic: Possible bug in latest beta with expandable panel that shows track listing  (Read 1698 times)
Sigma
Before updating to the latest beta, the expandable panel that opens when you click on an album looked like this: -
http://i.imgur.com/l3kqKAY.jpg
So each column shows 8 tracks and the artwork fills the entire area.
After updating to the latest beta, it looks like this: -
http://i.imgur.com/IrYbfw6.jpg
Now each column shows 7 tracks instead of 8 and the artwork no longer fills the area.
I'm not sure if this is a bug or if it's by design, but if it's by design it seems wasteful to me. The expandable panel seems to be 10 pixels taller now, yet it shows fewer tracks per column and smaller artwork. I definitely preferred the way it looked before.
Thanks!
Last Edit: June 22, 2016, 05:18:07 PM by Sigma
its by design. I guess it doesnt look as good when colours are not auto-picked. I might change it
Sigma
I like that the auto-picked background is not a solid colour now, as I think this.....
http://i.imgur.com/P5XfY9j.jpg
looks a lot nicer than this in terms of the background.....
http://i.imgur.com/Htimcpr.jpg
but I think a mix of the two would look best. Keep the old panel height (or keep the new height, but 8 tracks instead of 7 if that looks nicer), 8 tracks per column, and artwork that fills the space, but have the new background style. I think that would look good whether you use auto-colours or not and it's not increasing the panel height, but reducing the column/artwork size.
Last Edit: June 22, 2016, 06:09:19 PM by Sigma
