Author Topic: Hotkey for "Reset search and browse filters" bug  (Read 1551 times)
The hotkey for "General: Reset search and browse filters" is not working properly if you restart MB with thumbnail browser filtered into an item. Then the hotkey goes back to the filtered state at start instead of resetting itself.
Thanks, now the hotkey resets thumbnail browser. But a new behavior with this version is resetting doesn't return focus to "All" item at the top. It's rather a strange state. No item either from thumbnail browser or from main panel is selected, but the node somehow remembers the previously selected thumbnail browser item and keeps going back to the position when switching back from another node.
If I run the hotkey from column browser, focus returns to the "All" item at the top of the column as expected. I'd expect the same behavior for thumbnail browser, but it doesn't work that way.
i will leave the behavior of not selecting the top element (you might notice its the same on startup) but i have changed it to go to the top of the thumb browser
Thanks! BTW the name of this hotkey is not clear as it has nothing to do with library filters.
A more accurate name may be "Reset Filtering Browsers to No Selected Item" or "Reset Filtering Browsers to No Selection".
