Author Topic: Playcounter not updating  (Read 2494 times)
Kakifrucht
  • Tasty
When listening to a song, then manually editing the playcount tag, incrementing the playcounter by listening to the song and restarting Musicbee, the playcounter will be reset to the manually edited value.
Aevaris
I tested this and it is occuring to me as well. If you edit the playcount, further plays of the song will not increment it.
Aevaris
Nope, I lied, I'm just dumb. Mine incremented on further testing.
Kaki, make sure you are playing the majority of the song. If you don't play more than 50% of the song, it wont count as a play. This includes jumping to the end and letting it finish. If you didn't play the majority, it wont count.
Kakifrucht
  • Tasty
The playcounter does increment, however once you restart MusicBee it will be reset.
