Author Topic: Import/export of settings  (Read 1619 times)
cenver
Hello,
Is there actually an option to export/import settings? I have spend lot hours to personalize MusicBee perfect, so I wonder if there is possibility to export whole settings to one file, and then easily import them, cause in the near future I'm going to clean up my PC.
Thanks in advance.
Cheers!
You want the backup library command in the file menu.  Also check out backup & restore on the wiki (link in my sig) for guidance.
