Author Topic: AutoDJ not working?!  (Read 4047 times)
h0m3r
Hello,
my AutoDj stops working.
complete libary and no filter.
what is wrong?
what can i do?
Musicbee 3.0.5996
Greetz
h0m3r
working fine here. Check the error log and also try restarting MB
h0m3r
error log shows nothing about the auto dj.
musicbee restart...pc restart. i delete the musicbee3settings.ini.
nothing helps.
i dont now what's happened.
--edit--
when i check "also stream tracks from xbox..."
the "xbox Tracks" are displayed but nothing out of my libary.
is there another file where auto dj settings stored except in the musibee3settings.ini?
Last Edit: June 03, 2016, 07:51:02 PM by h0m3r
Try Tools> Advanced> Rescan All Files to see if it helps.
BeeBeeKing
h0m3r
I have already made this...nothing change.
Is the music in your Inbox perhaps?
no, my complete music is in the libary.
sometimes when i click "Preview" one Album is displayed me.
Nothing more. When i click "Preview" again the same Album is displayed me.
if you edit one of the files in the library, in the settings tab, do you have Ban or skip when shuffling ticked
h0m3r
no the funktion "exclute from Playback" I use never.
I get it not even fixed if I delete the musicbee3settings.ini
I do not understand that. very stange.
in that case PM me a link to your library database:
MusicBeeLibrary.mbl which is in the root Music\MusicBee folder
