Why do you have one more music rule for the same drive and folder?
Probably because im confused.
Im not trying to do any complex stuff here.
Basically what i wanna do is rename the files and folders that is inside G:\Music (Not copy or move, just replace the old names)
This is the only (monitored) folder i have where i keep the music. When using the send to and move files to organized folder i managed to rename the files.
But the auto-organise got me confused.
The library folder is located on the C: drive, but all the music is in G:\Music. But thats ok isnt it? Or should i keep the music in the library folder?
Do you have any idea what rules i should enter?
