Author Topic: Media Controls on keyboard don't work  (Read 2752 times)
8166UY
Like the title gives away: the multimedia buttons on my Logitech Wave Keyboard (Y-UV90) doesn't do anything with musicbee. Also, the button configurator doesn't seem to recognize them. MPHC and Windows Media player do work. I'm using W10 x64 and the latest drivers as well as the latest patch of musicbee 3. BTW, I start musicbee as an administrator to have less problems syncing with my phone.
Aevaris
For the media controls:
I have a microsoft sidewinder x4. When I used WinAMP, I had occasional trouble with the media buttons depending on what macro-set the keyboard was using. I'd suggest reviewing your keybindings (likely through Logitech's app) to make sure they are using the standard media functions and not something funky.
For the phone syncing:
Make sure your phone is unlocked for the duration of the sync.
8166UY
Nothing wrong with the key binding (all default and active) and I don't see the syncing thing as to be a big problem. ;)
