I upgraded to MusicBee 3.0.5988 last night and noticed that MusicBee 3.0.5988 Computer Folders Does NOT Show WPL Playlist Files anymore.
In MusicBeee 2.5721, you can use Computer folders in Left Sidebar to browse to a local folder containing Windows Playlist (WPL) files and the playlists would show under the folder. You could click the WPL file and play it or view music files in the WPL playlist.
Example Computer Folder Structure:
C:\MyWPLPlaylists
> MyJazzMood
> MyFeelGoodMusic
> BestLoveSongs
> BestPartyMusic
> WorldGreatestBlues
This does NOTwork in MusicBee 3.0.5988. Please bring back this capability. Thanks. I will be happy to provide a screenshot if you require it.
I know you can import WPL playlists. However, imported WPL files are static & do not change when the original WPL file is modified (songs added or deleted) requiring you to reimport the WPL everytime a change is made to the original WPL filles.
