Author Topic: Removing old custom tags  (Read 1808 times)
sleepless
Is there a way to remove the value of custom tags that were "Saved to MusicBee database only"? I want to replace one of my old custom tags with a new one. I've renamed the tag, but all values from the old tag still remain.
EDIT: I was also wondering if there is a way to move custom tags that are saved in the MB database only. So if I have Custom Tag #11, (Save to MB database only) and I want to switch it to Custom Tag #16. Is that possible (without losing all the tag info)?
Last Edit: May 29, 2016, 07:50:53 PM by sleepless
Advanced Search & Replace from boroda74's Additional Tagging and Report Tools plugin should do what you're looking for.
Take a look at the Wiki entry: http://musicbee.wikia.com/wiki/Additional_Tagging_and_Reporting_Tools
Further questions about its use should be asked on the plugin's thread: http://getmusicbee.com/forum/index.php?topic=3833.0
