Author Topic: Splitting Flac and Mp3 folders  (Read 1462 times)
coleberhorst
Ok here's the ideal workflow I would like:
New files go to the inbox
I tag them and add them to library
If flac, they get sent to a flac folder (and maybe even auto-converted)
if mp3 they get sent to a mp3 folder
Some way to view both either through filters (currently using) or separate libraries
Is this possible? and if not does anyone have a suggestions for something better?
I think something with file naming presets might work for the folder moving, but I can't seem to find a workable solution.
Say you're using the following naming template:
<Album Artist>\<Album>\<Disc-Track#> <Title>
You would only need to add a parent folder to them:
$If(<.Ext>="flac",FLAC,MP3)\<Album Artist>\<Album>\<Disc-Track#> <Title>
For more details, consult the following guide: http://getmusicbee.com/forum/index.php?topic=10980.0
coleberhorst
