Author Topic: Threshold  (Read 37284 times)
Alumni
New skin added! If you're running Windows 10 this skin will match the accent color "default blue".
https://app.box.com/s/hftlha8a05p7dznotbdp5o701k4pqazz
Is it possible you share graphics source files for the theme (assuming they are vector)? Or should I wait for an updated version with SVG?
For the XMLC skins I didn't design the bitmap images myself, unfortunately they are PNG and not SVG.
What font are you using in that recent screenshot?
I think the font is "Lato". You can download it here: https://www.fontsquirrel.com/fonts/lato
How can I make my musicbee incl the layout look exactly like it does in the pic?
Player controls docked in the top panel, with the progress bar at the bottom - left panel visible, right panel hidden.
Last Edit: December 08, 2017, 01:27:02 PM by Alumni
Havokdan
Alumni
Links doesnt works here
Working for me, can you describe what happens when you click the link?
Havokdan
Nothing, I use the Jdownloader, and it indicates that the links are offline. Maybe it's because of the host on my windows, is it possible to have mirrors on other services?
Alumni
Added a new skin based on Microsoft's Groove Music: https://app.box.com/s/zg444rgnwehhatwrxyh96xudqiicgjgd
Check the original post in this topic for backup links hosted on Mega.
Havokdan
Thank You!
delpinsky
Hi @Alumni
I've tried for the first time your amazing skin ThresholdLight on the UWP app of Musicbee :-*
But I have question, since it's an xmlc file, therefore not editable:
Is it possible to customize the TOP PANEL to have the Artist name and Track name one line above the Main Player Controls/Progress Bar?
Because as it is, basically the Progress Bar truncates the Artist & Track name, since the Progress Bar can't be resized.
Maybe am I missing something in the panel customization?
Antkh
Hi @Alumni
Same request. It's very difficult to see track info. Alumni, is it possible to have customizable track info above progress bar?
