Author Topic: Threshold  (Read 39300 times)
Alumni
Is this how the progress bar is supposed to look, or something's broken?
I'm not sure what went wrong there. I haven't been able to reproduce it myself.
that looks very much like a bug from an earlier v3.1
Are you using last nights' version? If so, can you send your settings file
PM sent.
It seems it's about font size for track text. When set to bigger than 10 pt, the bar gets split.
Alumni
Skins updated with a new player controls layout.
Alumni
No ThresholdWhite.xmlc update?
It's now the same as the light skin.
Please note you'll need the latest patch to load these skins properly: http://musicbee.niblseed.com/V3_1/MusicBee31_Patched.zip
Havokdan
Oh, thanks, so I'll delete the "white".
digital
I am using the dark skin and I wish to remove the title and name on the main player control section - How will i accomplish that?
Or is there anyway to show the title and name in full? Doesn't make sense if it doesn't show the name and title in full on the main player section.
Or move the title and name on top of the progress or wave bar?
Also it doesn't even show the song duration and time remaining.
Last Edit: May 22, 2017, 03:59:01 PM by digital
Alumni
Introducing the new and improved flat skin, designed as an alternative to MusicBee's default skin;
CyberAP
Thanks for the great theme! Is it possible you share graphics source files for the theme (assuming they are vector)? Or should I wait for an updated version with SVG? I like the theme a lot, but its graphics need to be updated for high DPIs. This is how it looks on 4K resolution with 200% scaling:
garbanzo
This skin is slick, thanks for sharing it.
What font are you using in that recent screenshot?
bustarhyme
Hi Guys, apologies for being a total n00b(I have used musicbee for years but never tried tweaking the interface), I was hoping installing a skin would give me the same layout as shown in the skin preview pic but it doesn't seem to do that.
How can I make my musicbee incl the layout look exactly like it does in the pic?
Because that looks awesome and that's how I'd like my musicbee to look.
Many thanks in advance!
Alumni
New skin added! If you're running Windows 10 this skin will match the accent color "default blue".
https://app.box.com/s/hftlha8a05p7dznotbdp5o701k4pqazz
For the XMLC skins I didn't design the bitmap images myself, unfortunately they are PNG and not SVG.
I think the font is "Lato". You can download it here: https://www.fontsquirrel.com/fonts/lato
Player controls docked in the top panel, with the progress bar at the bottom - left panel visible, right panel hidden.
Last Edit: December 08, 2017, 01:27:02 PM by Alumni
