Author Topic: Threshold  (Read 38949 times)
Alumni
Edit: created a new topic for my latest set of skins.
Last Edit: May 22, 2018, 06:31:26 PM by Alumni
theta_wave
vpsaxman
Alumni
Updated the original skin (formerly known as Win10) and added a new dark version.
HaSte
brooker71
Sorry - skin doesn't load, I just get a message saying 'value cannot be null'. The only way I can get Musicbee to start again is by deleting the faulty skin.  :(
i doubt the skin is faulty. As a guess you are probably using musicbee 2.5 and will either need to upgrade to use this skin or you will need to delete it and then choose another skin
Michael Cross
A very beautiful theme that combines with the Windows 10 color scheme. I know you created this theme for their own use, but was wondering if there are intentions to create variants of this theme with other highlight colors besides blue. That would be great!
brooker71
Thanks Steven, I have since upgraded to the new MusicBee 3.0. I'm glad to say the new skin works in the new version.  :)
theta_wave
Even though I believe I'm going to be using DarkRed Flat until the end of time, this looks like a really nice, clean skin.
skyrockman
sepiah37
i'm new to musicbee (using it for 5 days now) and i'm using your skin from day one - aaaand i love it.
is there a way to get a version of this skin without the striped look in list views?
that would make the skin 99% perfect for me (the missing 1% would be a different highlight color).
or may i ask you to give the community access to a editable .xml file of your skin(s)?
ps: can we hope to see other skins from you in the future?
kind regards, s37
Last Edit: September 25, 2016, 01:44:25 PM by sepiah37
There are currently three skins by this author. Check the Add-ons section and search for 'alumni'
Alumni
For those who prefer it, here is a modification to remove alternating row colors:
https://app.box.com/s/m2avbggm0cupq8jw0qwg1ptc1ffx0h32
