I have some 24/96 FLAC files that I want to convert to AAC when syncing.
This always throws an error and no output file is produced.
If you do the conversion manually:
Send To> Format Converter
you can select "resample to 44.1K" to overcome this problem (this option is not available in the 'on-the-fly' sync settings)
Does anyone know if there is an extra option to put in the neroaacenc.exe encoding parameters to force the resampling to happen?
