Yes, I've tried, but it doesn't do what it used to do. I can't drag more than 1 extra thing into the main panel. And I can't get rid of the "files" in the main panel. It used to let you simply have artist picture in the main panel, with lyrics overlaid on top of that on the left side. Additionally, the album art used to be overlaid on the main panel below the lyrics on the left. When I get time, I'll probably just install an older MB, set it up using the old UI, then upgrade.
