Author Topic: Tagging Problem  (Read 1795 times)
StefanIvanovic
When Editor is open clicking on tracks in now playing list won't load tags. Clicking on tracks in library loads tags. This is 5960 problem, 5954 from portable doesn't have this problem.
http://i.imgur.com/Fmj9j0Z.gif
One more thing to consider. For high resolution 24bit files there should be check-box "Resample bitrate to 16bit", same as there is "Resample to 44.1K" check-box in Format converter. I just realized that when -s -8 -o for flac is used it resamples track to 16bit and that all my files I converted to smaller flac are now 16bit. I must use fb2k for HiRes files conversion as it has option to convert to FLAC 24bit with -8 compression switch
