Author Topic: "display first few tracks only" and "Add to Playlist"  (Read 3727 times)
With "display first few tracks only" turned on in Album & Tracks view, if you try to add selected tracks to a playlist, it only adds the visible tracks.
Latest patches (3.5/3.6)
Don't know if it's related to your fix, but right now clicking on the album only selects the visible tracks.
trying now its all working fine for me ie. right click on an album picture/ Add to Playlist adds all tracks in the album
is it happening for you in all cases or perhaps there are some other steps involved eg. left click on picture then right click on the picture (i tried that as well) but just an example of something that could have produced different behavior
I'm left clicking on the picture (result is the same if I right click, though).  Still happening on 3.0.5961.  (If it matters, I'm in Audiobooks - and I'm just seeing that the number of selected files is not correct.  Maybe it's just a display issue?)
Here's a GIF: http://i.imgur.com/wYt4Luo.gifv
so your basing that on the displayed selected count in the status bar?
that is wrong which i will look at fixing but if you perform an action the files should be selected
Indeed, adding the tracks seems to be working.  It's just the status bar that's incorrect now.
