From v3.0, portable MB no longer looks at user appdata folder where standard MB installation stores settings, etc. Hence as long as you're using v3, no issue will arise. If you're using v2.5 or prior versions, I'd recommend using only portable version for each machine as there's a slight chance settings could mix up between standard and portable installation.
