Author Topic: Show Left/Right Main Panel in Radio view - possible?  (Read 2287 times)
Twlf
Hi all,
I've spent some time customizing my install, and got it exactly as I want thanks to the new panels layout configuration screen (and included Bee78 theme). :)
However, I can't get the "Right Main Panel" (not sidebar!) to show when I'm in the Radio tab and I'd like that as I use it in conjunction with the sidebar to help display all the information -- lyrics, arts, sidebar player, playing tracks, last two of them being in the panel itself. Also, it's sometimes useful to have the stations mixed in with the current playlist/playing tracks.
https://i.imgur.com/aOvBExV.png
Do I have a gap in my knowledge or is this disabled for some reason / not possible to do yet?
Thanks.
thats an oversight. I have changed the next v3 update to make the right main panel visible from the radio tab. I will post a download link later today
Twlf
Sounds good. :)
Also, in case it's another oversight and not by design -- the panels don't show up in Music Explorer either.
Which I guess would fit in with the View's integrated playlist system, if it weren't for some of us who
disable the main player controls and use the sidebar player instead. :p
Just wanted to mention that as well in case it's something you'd want to amend.
Twlf
Thank you, Steven, looks awesome! :)
I'm getting some Exception message boxes now -- all reproducible on my setup, so if it helps, I'll post what triggers them.
Basically, if I first open on any of these by clicking them in the left sidebar:
a) Podcasts
b) Now playing
c) Music explorer,
then open something else in the same tab, (a folder, Radio, anything)
and then click on the Back button in UI, I get something like this:
a)
MusicBee v3.0.5950.27333 (Win6.1), 16 tra 2016 16:58:
System.InvalidCastException: Unable to cast object of type '#=qjXdJYtskgug24Bw4$IThJA==' to type '#=qrJIG0B9utVKwrls9ylMh2lDgkVK5kd71l$dm7$DMRzI='.
   at MusicBee.MusicBeeMain.#=qVAHHnXG6gnXz4JG8sBf53w==(Boolean #=qdzP4rX9s84V1haxF3cs6YvEKTyke$LqJLLoJfq_pp2c=)
   at MusicBee.MusicBeeMain.NavigationHeader.#=qer7joLggK_q$DVcfPMOM9Q==(MouseEventArgs #=quJe$AOOAcpxjiN9948e4ig==)
   at MusicBee.MusicBeeMain.OnMouseClick(MouseEventArgs #=qjRmZ2v$dF33AnLnkMtLr4Q==)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at #=qhZnIjQKGFJ2OwiUKcnhTqZlYiuGLPY4Z59WKUCRxzLE=.WndProc(Message& #=qKe0O60pcaLiFXWMNB7k3YA==)
   at MusicBee.MusicBeeMain.WndProc(Message& #=qte7qrPSkCEl6GfMu8cNo4g==)
b)
System.InvalidCastException: Unable to cast object of type '#=qhkNo96hei1d_$cQnVotoEvrkkAXQ8RpFN6BVtXltJDY=' to type '#=qrJIG0B9utVKwrls9ylMh2lDgkVK5kd71l$dm7$DMRzI='.
c)
MusicBee v3.0.5950.27333 (Win6.1), 16 tra 2016 16:59:
System.InvalidCastException: Unable to cast object of type 'MusicExplorerPanel' to type '#=qrJIG0B9utVKwrls9ylMh2lDgkVK5kd71l$dm7$DMRzI='.
It only happens with the Back button, doesn't get triggered by Forward button or simply clicking something else.
they are all the same thing. Redownload the link and the issue should be addressed
