I might have mentioned this before, but can't find a trace of it, and it came back as something I'd love to see/have in MusicBee.
Ideal would be to see if a playlist has a local/custom view (and with it a 'local' sorting applied on static export) at a glance, i.e. going back to this thread:
https://getmusicbee.com/forum/index.php?topic=23572.msg143931#msg143931As an additional/holistic approach for MB, ideal (for me) would be if, in Playlist Explorer tab/UI, we would have additional (optional) columns that could show/indicate features & stats of the playlist at a quick glance; like:
- sorting method (is it custom/local [and which sorting...?] or globally set (this might need an explicit local sorting feature for playlists...)
- view mode (global/local ?)
- file/track count
- play/length of all files combined inside a folder and/or playlist
- lock/unlock (an old re-curring feature request from various users)
[plus maybe even with switch-ability directly inside the Playlist Explorer UI on playlist attributes that make sense to be altered there directly, i.e. lock, sorting method, etc, directly on the column icon (via right/click?) ].
Just some thoughts.
Churs.
c.
