When that is done, the left navigator would only contain a single "Playlists" node and you would be able to navigate to other nodes in the left navigator and the Playlists section would remain in the left navigator.
You meant left main panel there, right?
yes thats right, although i am having seconds thoughts about doing it because I think "Edit Playlists" as described following should mean the Playlist Manager panel wouldnt need to be locked in the left main panel.
I was having a look at the latest iTunes and how it does things generally and for playlists. I have to say generally i didnt like it at all except for the "Edit Playlists" button which i think i will do the same ie. click Edit Playlist, and the playlist moves to the right sidebar and the music library (or whatever left navigator node you select) shows in the main panel. So you can easily drag tracks into the playlist. That way i can get rid of the 3 library nodes that currently display at the bottom of the Playlist Manager
For those of you who wanted the Playlist Manager as a separate element, given what i just said, is there a strong reason for still having that?
To be clear, while I am not opposed to this and can see ways it increases flexibility, i do think having it as an element will create some confusion, so i want to be sure there is a genuine need thats not covered by whats already there now or proposed above.
Just to recap what i am currently thinking:
- click on Playlist Manager moves the playlist nodes into the left main panel (differs from the current behavior which has the playlists in two places)
- click on any other node in the left navigator closes the Playlist Manager panel and the playlists move back into the left sidebar. I am not completely comfortable which these first two points but its the best i can think of for now.
- new Edit Playlists button as described above
- remove the library nodes from the Playlist Manager panel
- probably make the Playlist Manager panel also available as an element
