Author Topic: Sync goes over 100%  (Read 1922 times)
Peekstra
Sometimes Musicbee goes over 100% when syncing:
Maybe it happens because I sometimes only change the tags and lots of files are renamed, for example this sync shows the same song a couple of times:
The sync itself is successful and it happens in the latest 2.5 version (I haven't upgraded because 3 is still in beta).
This was fixed in the early days of v3.  I suggest you update as Steven will not be doing anything further with 2.5.  FYI - v3 is stable. You shouldn't let the 'beta' tag put you off.  3 is mostly a change to the GUI, with most bugs from earlier versions put to rest.  The percentage issue being one of them.
Peekstra
Thanks, I checked the change logs of 3 but I guess this was one of the numerous bug fixes.
I'll upgrade to 3 soon if it's considered stable.
theta_wave
I still see it in v3 and I've been keeping track with the latest v3 releases.  I never reported it though because I always kept my eye on the number of tracks being processed and ignored the percent-completed information.
