A very minor skinning issue:
The "<replacementElement" for the regular skin.xml doesn't seem to work when wavebar_skin.xml is also used.
Changing it's value in skin.xml has no effect for displaying the 'progressbar display mode'.
But the value as set in wavebar_skin.xml does not only affect the 'wavebar mode', but also the 'progressbar mode'.
(which is undesirable for this skin)
Not a pressing issue at all, but I'll pm the skin just in case it's something you would like to take a look at.
It concerns <replacementElement id="TrackRating" at the bottom of the skin.xml. It's value is not respected.
that should be fixed for v3.2
it seems this change is breaking some skins so i will undo it for now
