I'm asking for some help here because I suck at this. The MB date/time standard appears to be mm/dd/yyyy hh:mm AM(or PM). I need some help to convert that to the standard yyyy-mm-ddThh:mm:ssZ . So, my date tag that looks like this: 2016-03-25T17:52:00Z is automatically re-written by MB to display this: 3/25/2016 12:52 PM.
-Is it possible that MB is somehow determining my time zone? Why else would it not convert the time to 5:52 PM? I don't remember entering this info at any point. I'm at GMT-6 but use a VPN so that might be the cause?
-I would also like to create a second tag which cuts out the time display (yyyy-mm-dd), but I think I can handle that if I can get some help with the full conversion. Also if the full date/time conversion is too complex, I could be satisfied with just the date.
-Unfortunately MB automatically re-writes all of these tags. I can generally avoid this as long as I don't ever save any changes in the tag editor, but I seem to forget often enough and it really sucks when it happens (adding cover art to a single podcast can result in hundreds of my files being rewritten). So besides the display purpose, it'd be nice to have this script to convert the tags back when this happens. Also, I use the yyy-mm-dd template for naming/organizing my podcast files so I can't use MB's naming template until I have this figured.
Anyway, I have no idea where to even begin with this, so your help here would be very much appreciated.
EDIT: I should also add that another part of the reason I need to keep this format for the date/time tags is because I still need to use itunes for podcasts. Itunes does not read tags in the MB format and will not organize them
