Author Topic: Quick filtering  (Read 757 times)
ChriUwe
It would be very helpful and informative if the quick filtering was made visible in the status bar.
this is done for the next v3.5 update
ChriUwe
Thank you for being able to do this so quickly!
Wouldn't it also be very useful in this context if the column browser were also filtered according to active filtering?
