Hi everyone!
I love MusicBee but I have an iPod and the
current plugin seems to be discontinued, so I tried to roll my own, mainly to fix the tiny problems I had with the current one (Like synchronizing twice made duplicates in my playlists, it was rather slow and stuff).
I tried to fix the problems in the current plugin, but I had lots of troubles understanding the code, so I thought it would maybe be easier to just start from scratch taking ideas from the old one.
This one does not use the storage API (I couldn't get how it worked and never could make it work), so it just uses a menu item that triggers the synchronisation.
For now it only support iTunes, but I usually try to make my code the most reusable as I can, so support for other music players could potentially be added, as long as the targeted music player have some kind of API that could be used.
Features are pretty basic: it synchronises your playlists between MusicBee and iTunes. It basically takes your MusicBee playlists and reproduces them exactly in iTunes.
It could be used to synchronise all the tracks as well as the playlists, but I didn't need it, so if anyone needs it, just ask, I'll try to add it.
More informations are available on
Github. If you want to ask for a feature, say my code doesn't work or anything, you can either file an issue on the repository, or reply to this topic. I'll try to reply as quickly as possible.
Releases are available on the repository
as well.
tl;dr: Plugin that synchronises your playlists from MusicBee to iTunes and possibly more in the future. Info
here and releases
here.
