Author Topic: Playlist Track Count  (Read 6923 times)
I'd like to see playlist track counts.  For GUI consistency, I envision this being presented in a manner similar to the podcast and inbox counts.  But in that case, the background box would have to change size dynamically.  If that's a problem, then perhaps the count could appear in parenthesis without a background.  Similar to the way SubSonic does it:
+1
I think this has come up before.  I have done this manually for some static playlists, but it's impossible to keep up with in other cases.
I guess it's just you and me, psychoadept.   :(
Maybe this could be added as a feature of the playlist manager for 3.1.
That would be better than nothing.
I'm bumping this in hopes of getting it enabled for 3.1
  • MB Version: 3.6.8830 P
+1
Pingaware
+1
it shouldnt be a problem for static playlists but i think it would be a problem for auto-playlists. Whats the reason this is needed?
I'd like it so I can easily see how many tracks are in each list.  The way I do it now is to select the playlist and then switch to Track Details view and look in the right status bar.
And since most of my playlists are auto-playlists, if it can't be accomplished for them, I'd say don't waste your time on this.  But that's just me.  Other users may still want static-only.
Thanks for the consideration.
Last Edit: May 08, 2016, 05:02:06 PM by phred
Yes, it's a convenience factor. A quick check that doesn't require digging into the playlist to get the info.  Especially for playlists that require an action, it's like the inbox count
theta_wave
I don't know about this, as it will add unnecessary visual clutter in my eyes.   I am quite fond of having a clean look to my left panel.
Do you not use podcasts or the inbox?  Track counts appear for those nodes.
I imagine it would be optional anyway. (Actually, a per-playlist setting would be excellent, in my opinion)
