Author Topic: Reverse Syncing with iTunes  (Read 1737 times)
Statdustfists
Hi I'm new here I downloaded Musicbee last night and it looks pretty good. Got to sync some playlists with my Galaxy Tab S2 and they turned out great. My question is if I've imported a playlist from iTunes and I add new songs to it on musicbee is there any chance that it will also update the original playlist in iTunes. If there is a way to do this I would greatly appreciate help thank you!
You could use import playlist command from iTunes (File> Library) using exported MB playlists.
