Author Topic: New questions for the wiki  (Read 24038 times)
What interrupts a playlist mixer cycle?  I mean, once you start a playlist mixer, what actions will cause it *not* to continue adding to playing tracks?
anything that invokes loading new tracks into the Now Playing list eg. say double clicking a track in the main library panel.
Actions such as skip/ double click a track in the Now Playing list/ and even clicking Stop and then play again shouldnt stop the mixer
If "display using view" is anything else, then only that playlist will change when you change the view in the main panel.
No, all other playlists set to the same view change as well.
Please reread what Steven said above.  If you change the "display using view" to anything specific, it no longer affects other playlists.  I've also tested this.
We're talking about default fields playlists, right?
If you change "display using view" away from default it sets "displayed fields" to default automatically (because custom fields no longer has any meaning - The whole thing is custom).  One of many things I hadn't understood until now.
Just the fact we're having this discussion shows that the current settings are very unclear. :)
Last Edit: April 01, 2016, 07:09:17 PM by psychoadept
I'm not sure I follow you. Are you saying if you change view setting from "Default" to "Album & Tracks" view, then custom fields setting auto-changes to default fields setting? That's not happening with my MB.
I just tested again (3.0.5934), and I see you're right.   Even if "display using view" is set to a different view, if it is set to "default fields" it will reflect the default fields for that view.  (I know there have been cases when "use custom fields" has been reverted to "default fields", but I can't reproduce it right now.)
So that's another possible permutation.  But "Default" still operates differently from all other options for "display using view", because changing the view in the main panel will affect all "Default" playlists, but if you change "display using view", only that playlist changes views when you change it in the main panel.  Test it.  :)
I know what you mean. That's one thing I didn't like when we had a previous discussion about this:
For filters/playlists, current view setting options are misleading since now switching views constantly updates the initially saved view setting.
Pingaware
Note that dragging tracks in manually doesn't seem to break the cycle.
Where does the "auto-tag" function in the Tag Editor get its data?  It looks like an amalgam of the various auto-tag functions.   I have been testing it with songs that seem like they should be pretty easy to identify, and most of them have returned with no changes.  One (out of about 10 so far) came up with a new genre tag, but that's it.
Edit: today, it's coming back with the message "web service failed with error", but that wasn't happening previously.
Last Edit: April 30, 2016, 04:23:14 PM by psychoadept
its working ok for me and fields are being update, although MusicBrainz did return a protocol error once. I gather they need to upgrade their servers due to overload so its probably just a temporary issue.
I am getting a couple of cases where artwork randomly doesnt download from one of the hosts for some reason so i will investigate that
edit:
the issue with the artwork is fixed for the next update
Last Edit: April 30, 2016, 06:55:37 PM by Steven
Thanks.  I'll try it again.  (And yes, I thought it might be the MusicBrainz issue.  So far I have only seen genres updated, but I'll let you know what happens with the new version.)
What size, precisely, are the small, medium, and large thumbnails in the thumbnail browser?
Where does Artist Biography get its info?  I was surprised when Xbox Music and last.fm were both a bust, but it still had a bio.
its not obvious? each should affect the size of the thumbnail image. Is that not the case for you?
last.fm and echonest (while echonest is still available)
I can see the size change, but I was hoping for # pixels. :)
