Author Topic: Locking/Pinning Tabs  (Read 24688 times)
I think Firefox's way is more suitable to MB's pinned tabs especially to make them serve as an alternative means to left sidebar.
+1
Would it be possible to have pinned tabs also remembering the opened state of the docked edit panel?
for the next update i have made the following changes:
- tabs can be pinned as: Icon Only; or Icon and Text
- if Icon and Text is chosen and the tab is not active, the tab will display with the usual text but at a minimal width. Except for the Podcasts or Inbox node which show the counter as the text value
- if a tab is active, the current behavior is the same as now ie. the tab is shown at full width and with the usual text
- when a tab is first pinned, the left sidebar will be hidden but there are no restrictions afterwards eg. it can be re-opened and you can navigate to a different node which is remembered on restart
Then I don't really get why one would pin a tab. What's the benefit?
Try the current lock tab feature. It does the same thing - prevents it from accidental closing and remembers last location on restart (just like all tabs in MB for the second). It's rather better as it doesn't arbitrarily hide left sidebar when first set up.
You never explain why you don't like Firefox's way of pin tab feature though I elaborated why it's more suitable to MB.
i am fine with the idea of opening a new tab if the user clicks on another node.
What i wasnt comfortable with was how the handling for custom and global searches would be done. However now i think i feel ok with restricting the searches so only the current pinned node is searched so i will look to implement that in the next few days
  • MB Version: 3.6.8849 P
When this topic was first raised I mentally shouted, "You beauty!"
I thought it was the first step in moving towards hiccup's request of configuration presets.
I had a vision of pinned tabs holding those presets and being able to quickly access them from a drop down window
icon for pinned tabs
icon pressed
But sadly, the pinned tab is basically the locked tab by another name.
That'd be great!
I'm not sure I understand the search issue. If the user performs global search within a pinned tab, can't you instantly move it to a new tab as well? And when the user closes the search results node tab or clears search term in the search box, return focus to the original pinned tab.
If it's not possible for some technical reason, maybe we should accept the limitation.
I think we're moving to that direction (except the dropdown part). hiccup's proposal probably needs new implementation of custom layouts (like custom views). Then we could apply to each tab a custom layout for whole panel config and then a custom view for the main panel, if implemented that way. Then each pinned tab could retain a completely customized layout for selected node.
I hope so.
I'd be more than happy to be proven wrong :)
@Bee-liever, i havent eveen considered hiccup's suggestions for saved configurations and i think it requires some thought and should be outside the scope of whats done for tab pinning. Its not something i would do for v3.0
i think that would be a bad user experience for a new tab to be opened when doing a search.
I will go with the idea of always restricting searches to the pinned tab
@Steven - I know that the pinned tab option is evolving, but I'd like to understand pinned tabs vs locked tabs.  Is pinned going to replace locked? If both will exist, what are the differences?  What is the behavior of each and why use one over the other?  Thanks.
Then how can you do a global search when you're in a pinned tab?
Open a new tab, search there and then close the tab and return to the original tab?
a locked tab just disabled the close icon. I have removed that option/ functionality to reduce confusion
yes
Thanks Steven.  I'll have to find something else to blame the next time I get confused.  :)
