Author Topic: Albums with same name but different year  (Read 3407 times)
duplicate
If an album has the same album artist and album tag as another, even though the year tag is different, all songs get grouped to one album. One solution is naming the albums differently, as I did in the case of "Cartola (1974)" and "Cartola (1976)". Is it possible to have two albums instead? In this case, I would want something like so:
You could add Year to the criteria in sorting/grouping preferences
Latest patches (3.5/3.6)
duplicate
And here was I messing with RegEx... Works like a charm, thanks!
Alumni
If you're not sure where to find this, it's under preferences and sorting/grouping, look for the section that says "grouping - specify how files are grouped to an album". Fields 1 and 2 should be artist and album name, so add a 3rd field for the year.
