Hi, as the title says i've got problems with the Sync of my HTC ONE with Musicbee, everything works fine but the sync of FLAC files.
I set up MusicBee to convert FLAC to mp3 while syncing with the phone, the synchronisation problem goes well but not all the tracks are synced.
The tracks that are not showing up are the ones that comes from a single APE File with its related CUE.
If i decide to export manually onto the device everythings works correctly, so i assume the problem is in the SYNC process.
