Author Topic: Dark Touch [bitmap]  (Read 13390 times)
  • MB Version: 3.5.8402 P
ATTENTION!
This skin has been updated for MusicBee 3 and later.
Compatibility with version 2.5 or earlier is not guaranteed.
The replacement for Metro Touch.
With a change away from the round metro style buttons, I thought a new name was needed.
Dark Touch
Amethyst
Othe Colours
Updates
December 20, 2017:
  • MusicBee 3.1 changes incorporated;
  • added images for high DPI screens;
  • playerbar reworked to include larger volume bar;
  • themed No Artwork and Unknown Artist images updated;
  • icons updated.
Downloads
All skins are in one folder: Download from Skins section of MusicBee Add-ons here.
Installation information, and more, can be found on the wiki
As always, any mistakes or problems, please let me know.
Last Edit: December 20, 2017, 12:40:47 AM by Bee-liever
Updated for 3.1
(sorry for the delay on this one, but had to rebuild it from scratch)
Download link and changelog in first post.
rockola-man
I downloaded the skin and noticed volume control is missing on main player.
It's here:
on highlight it changes to:
Last Edit: December 21, 2017, 09:17:21 AM by Bee-liever
@Bee-liever;
I can't see the pictures. Looks like the site's server is down.
@Bee-liever;
Working fine for me but changed them to imgur, just in case others were having problems.
rockola-man
Still don't see volume control under player controls. Don't know what I did wrong or don't have set right. speaker icon is not there.
running windows 10 up to date on surface pro 4.
Try changing your screen resolution or display size. Make sure it's at 100%. Since the elements you can't/don't see are at an edge of the window it may be that they're out of sight.
Posting a screenshot of what you see might be helpful.
but what version of MusicBee?
rockola-man
running musicbee 3.1 update. was using last version of this skin and worked no problem. do like this version because of bigger volume button. Tried different setting to no avail. I did try this version on a desktop and it showed up fine. Guess something to do with surface pro 4.
meowie
OMG that font is so neat, pls tell me what’s its name pls!
edit: i meant font for headers in the music library. I didn’t even know that was possible (to change shape of letters in accordance with structure of text)! So neat!
I made acc just to ask this question :)
edit2: btw nice skin. I am currently using green version and am very satisfied!
edit3: and happy new year lol
Edit 4: you can just tell me font family name or name of some similar font. I tried searching through my fonts, but don’t have any similar to this. I guess it is some all-caps type, I tried googling for something similar, but couln’t find any font with these capabilities :(
Edit5: OK no need, I found the one that suits me right  :P
Cheers  ;)  :P  :P
Edit 6: Meowww
Last Edit: January 02, 2018, 12:52:10 AM by meowie
Adson
I like this skin, very well done  :)
Is there a simple way to make the background a little bit darker?
I would to do that myself but it seems that the xmlc files are encrypted or at least not readable by notepad++.
Thanks for the skin and any help on this.
Cheers  ;)  :P  :P
For future reference the font is Sinzano Regular Interlock There is a link on the Peaches'n'Cream skin page.
If you check out redwing's guide here: https://getmusicbee.com/forum/index.php?topic=22023.0 and any current .xml skin, you'll be able to modify the skin to your liking.
You wont be able to change the colours of the player bar buttons, as those images are embedded into the skin.
RockPigeon
I was wondering if you could explain how you have two columns before the artwork field? You have YYYY and A (I'm guessing Artist or Album Artist? When I try to put a field before Artwork, it doesn't allow me to. I really like how you have it setup with the years descending like that so you can filter by year like that. I've replicated everything in your image except that.
Thanks!
The A is part of A-Z.  It's the column browser in vertical (side-by-side) mode using YYYY and the Custom AZ bar set-up by redwing.
You can find redwing's guide for that here.
