Author Topic: easy transfer libraries from PC to other PC  (Read 1178 times)
nazz
The installation and use of my music with MusicBee is Year by Year, Types (Blues, Ethnic, Jazz, Classical, aso)... about 50 libraries... it's for me the better way to find and hear music with various and fast enties and no filters (about 35.000 tracks)... i'd wish to transfer the names and settings of this libraries from my "big" PC to a "little" Portable PC... I tried to copy the folder "Music" in the folder "Music" of the Portable but it does works... Then to copie the folder .mbl and not works... Must each time recreate or use tedious ways... Is there someone here to help me ? thank's...
Probably it involves settings files as well which are saved under AppData folder.
BTW I don't think maintaining that many libraries would be more efficient than using filters/auto-playlists within a single library. As you asked in another post, support is limited for such use as it would be rare.
