Author Topic: taskbar player disappeared?  (Read 3307 times)
wtkafe
For some reason my taskbar player isn't showing anymore when I hover over the musicbee icon.  I don't remember changing any settings.
Anti
Same. The buttons don't work. Using MusicBee 3.
are you guys saying the same thing?
So Anti, the taskbar player shows but the buttons are completely missing/ disabled/ simply not responding when clicked?
when you try, do you have the main player/ compact player or mini-player active?
wtkafe
For me the back, pause, forward buttons don't even show
i think windows does that is you are using windows basic, you disable aero-peek, or the desktop windows composition manager is disabled
wtkafe
Just checked all three of those, none of them are the problem. It's weird cause it was working fine and it just suddenly disappeared one day.
Anti
My buttons are back.
I haven't restarted Windows or changed any settings, but have restarted MusicBee several times since.
I am using a custom Aero theme.
wtkafe
same. I restarted also and the buttons came back
