Author Topic: Installed NullSoft Module Decoder but cannot import tracker modules [3.0.5864]  (Read 9947 times)
theta_wave
How did you install in_modplug.dll?  I extracted it from its installer using 7zip and copied it into MB's plugins folder
in_modplug.dll I extracted the same way. in_mod-2.2.10b29.dll (as you would know) is already extracted.
I used MB in admin mode to import them into the Plugins folder, just in case MB makes some record of the path in it's settings that just copying directly doesn't do.
That is what I did too.  I extracted in_modplug.dll and used MB's import winamp plugin while as admin.  If there was a debug mode for MB, then maybe I can see what's going on.  Oh well.
  • MB Version: 3.6.8878 P
Don't forget that in_mod-2.2.10b29.dll is the only one I've been able to get to work consistently, without the BASS errors.
theta_wave
Hmm, could you list which dll's did you moved into MB's directories and where?  On my end, I still have that 1s of playback problem.  On your end, I assume that with in_mod-2.2.10b29.dll you are able to listen to a tracker and (maybe) seek through it.  Thanks.
Yep. Full play and seek
basszxtune.dll is in Program Files\MusicBee
in_mod-2.2.10b29.dll is in Program Files\MusicBee\Plugins
The only other thing I can think to do would be to turn off inherited permissions and take full ownership of the .dll (Properties> Security> Advanced)
theta_wave
Hmm, I have full ownership of the MusicBee, directory thus anything else in its subdirectories, so I should have full ownership of the dll (just checked, I do).  However, I don't think I tried basszxtune.dll and in_mod-2.2.10b29.dll combo yet.  It has been basszxtune.dll and the other plugins (modplug, in_mod 2.2.11).  Is your basszxtune.dll from the un4seen site?  Site URL: http://www.un4seen.com/forum/?topic=15694
Yes.  This version (basszxtune-v2.4.4-win-x86_64-bin.7z) from the sourceforge page link.
Nokiaman
Sorry for bumping , but this just doesn't work. Not to mention the above reply makes no sense. MB is 32-bit program and can't use x64 DLLs at all.
