Author Topic: MusicBee 3 Bottom Panel  (Read 3999 times)
ihavnoclue
I was excited to see the release of MusicBee 3, so I installed it, I just have one issue.
Is it no longer possible to have artist information show up in the bottom panel? I like having the Now Playing List and lyrics on the right and all of the song information/Wikipeida/Last.fm plugins on the bottom as shown in this screen shot:
I also just noticed in my screenshow that I have 2 Last.fm Stats tabs, not sure how that happened...
its now called the "Now Playing" bar and can be chosen using the Panel Layout dialog
ihavnoclue
Thank you!
Is it still possible to have the photos tab there? I can't seem to figure that out either. I saw that the Last..Fm recommendations can now only live in the services pane, which is a little disappointing.
The now playing view in MusicBee 3 is really cool though!
Thank you!
the last.fm recommendations needs a new version of the plugin. See the end of that topic for a download link and the recommendations will appear as a node in the Services section of the left navigator.
The photos will not be included in v3
ihavnoclue
Yeah I found the updated version and was using that. I was just hoping there was a way to put it back on the bottom instead of in the services tab.
Ah great!
