Author Topic: Numbering tracks  (Read 2195 times)
supercamaron
I can't see to find this out.
How to number a batch of tracks all at once starting with 1? Say I'm editing 10 tracks, I want MB to number them in order (1,2,3....). I'm sure the option is there but can't find it.
Thanks
UK82
Select the tracks you want to renumber and then go to:
Tools / Tagging Tools / Renumber Tracks
That should do the trick.
supercamaron
Thanks!
That does it. Is possible to do it from the tag editor though? there seems to be some options for numbering but all I've managed is to set the same number for all tracks.
