Author Topic: Zen Hive  (Read 41125 times)
download Zen Hive
This skin will only work under MusicBee v3
Not under current official v2.x release versions
update:
The player panel is completely redesigned and now a lot slimmer:
Last Edit: June 11, 2022, 10:27:40 AM by hiccup
  • MB Version: 3.5.8402 P
Very interesting player background treatment :)
might need to check your tabs-in-captionbar elements and the narrow scrollbar border for playing tracks
WOW!!!
I like the little bee progress marker.  Very clever.  Also the treatment of the Shuffle and Repeat on/off.
I see one possible error (unless it's intentional) -
The vertical line dividing the main panel from the right sidebar doesn't go all the way to the bottom.  It does go to the bottom on the left side.
Thnx Bee-liever, both are fixed.
WOW!!!
No, that's not intentional, and I doubt if it's solvable by skinning.
I can't replicate it in my setup, but what is the panel you have positioned left of the lyrics panel?
I think you're right.  It's that way on the MB3 Default also.  I guess the "missing" line is only noticeable when there's a dark bg with a light fg.
To the left of the Lyrics panel is the Now Playing panel.
Yep, the now playing panel overlaps that border line.
it's up to Steven if he feels like changing that.
Understood. I assume it's an oversight since that line exists top to bottom on the left side of the main and playing tracks panels.
Is the dark blue bg2 colour on the scrollbar arrows intentional?
Wow, you guys have laser-vision.
Fixed that.
(and please keep 'em coming... )
The link is missing from the first post.
It's back.
(I was making a minor change)
phred, could you send me your settings file?
I am getting a report that the download link for this skin is not working if you don't have a MS OneDrive account setup.
That would be new to me.
Could somebody without a OneDrive account please report if he/she can download this skin from THIS link, or if that link indeed has any obstructions?
edit:
Fixed it, something was wrong with permissions settings.
Last Edit: January 02, 2016, 08:11:03 AM by hiccup
MeeMeeMee
Please add a screenshot(s) to your original post to wet our appetites
Edit: Thank you! It looks gorgeous, although the bottom player controls looks to me a bit busy.
May I ask about the icons set you use? Where can I get it?
Last Edit: January 05, 2016, 10:42:38 AM by MeeMeeMee
MusicBee 3.5.8516 / Windows 10 (64-bit) / Intel i5-3470 / 8GB RAM
Media on NAS (CIFS share)
Get the latest patch: https://getmusicbee.com/patches/
