Author Topic: How to change the "no cover art" image?  (Read 5070 times)
Eflan
I use the custom theme "Crimson Creme", it's almost perfect, thanks to the one who created it. The only change I don't like is the "no cover art" image, he puts a blur bee in place of the default image.
Crimson Creme : http://www.imagebam.com/image/621b17454795508
Musicbee Classic : http://www.imagebam.com/image/b43164454795515
Can you tell me how can I put the default image without changing theme?
Thank you in advance.
Last Edit: December 27, 2015, 08:56:33 PM by Eflan
This requires changing the skin file.  Does it have an .xml extension or an .xmlc extension?
Eflan
Thank you for your reply and it's an .xml extension. It is possible to do it?
Last Edit: December 27, 2015, 11:11:02 PM by Eflan
Yes, you should be able to do it yourself by editing the file.  I suggest making a backup first, just in case.
Find the point where it says  <element id="NoArtwork">.  Delete everything from there to the next place where it says </element>.
Eflan
Haha it works but now it's yellow : http://www.imagebam.com/image/819e5d454877746
Do you know how can I recover the default grey?
Try replacing the part that you deleted with the same element from the MusicBee Default .xml file.
Eflan
In fact, I tried before posting. But the Music Bee Default skin has an .xmlc extension and I don't know how to read it.  Sorry, I'm such a noob. :(
It's not in that file, anyway, because it's the default.  I'm confusing myself, sorry.  I'm honestly not sure what to do about the yellow.  You can replace the No Artwork image with anything you want, though.  You just need to find an image you like and convert it to Base 64 (it'll look a lot like the gibberish you deleted).  Then you can insert it into the skin using that element.  This is a handy page for encoding base 64 images: https://www.base64-image.de/
rurutia10
If all else fails, try the calcium metro skin. think you'll like it.
Eflan
A version of Crimson Creme with a plain No album art picture: http://1drv.ms/1OUOLza
(temporary link, will be obsolete in a couple of weeks)
