in v3, the user has the option to remove the auto-dj node from the navigator. If the user chooses to remove the auto-dj node, i guess it makes sense to also remove the auto-dj from the shuffle mode toggle button as well so i will do that for the next v3 update
What you can do in the meantime is use a hotkey.
For example, I have a global hotkey set for it (Player: Toggle Shuffle Mode) and it's what I use most of the time to toggle the option.
Using it just toggles shuffle on and off, so you don't bother with AutoDJ.
There is a problem still.
I'm using a global hotkey just like
vitesse, but I'm guessing he's not using V3. When I used V2.5 it worked just as he described it, but now it doesn't. I even removed the Auto-DJ node, and it doesn't work like I want it to. Clicking the toggle button now works fine, but I mostly use the hotkey. Can you please fix it Steven?
