Hi,First post so....First time user..........so i was thinking if i can add local radio stations to streaming list.........like I am from India so........if possible can anyone let me know
Very easily done as long as you know the station's stream URL. Right-click on the radio node and select New Station. Then fill in the URL and MB should auto-populate the rest of the info. If it doesn't you can fill in what you want. Save it and play it.
Unfortunately MOST(if not all), radio stations in India does not have ANY streaming services. it uses old radio bands. There are very FEW, that uses streaming.
