Author Topic: Last Played Tag Question!  (Read 1350 times)
fkm
Can someone tell me if there's an issue with the Last Played tag as it doesn't seem to be showing all songs I've played recently.
I've created a playlist to show last played songs in the last 1 days. But it only shows say 3-4 songs when I've played say 30.
Thanks for any help!
i suggest you display the last played field in the main panel and then sort by it. If you are sure there are songs you played where the date hasnt been updated, then keep an eye on when it doesnt update and what the circumstances were when it doesnt update. Also you say how you filter for those files so it might be something wrong with your selection criteria
