Title is pretty self-explanatory. If I try syncing but I have my one autoplaylist on my device, all of the new songs will sync (and those to delete will delete), but even though Musicbee says it's updating playlists, none of the playlists will change. I eventually pinned the problem down to it being the autoplaylist that prevents the playlist update (after before having to delete all playlists just to update them). Every time I want to update the playlists, I manually delete the autoplaylist, but I figured it's probably a bug and I should report it here.
I'm using the latest version of Musicbee (this issue was there a few version ago too) and I have a Galaxy S6 Edge.
