Author Topic: Play Count Settings  (Read 2529 times)
wtkafe
Is there a way to set the settings so that the play count adds 1 only if the song ends, not just if # secs are played. Also how come the play count adds 1 even if I pause a song for a moment?
You can set the play count increment to a percent rather than a number of seconds.  It's in Preferences > Now Playing.
wtkafe
What I meant was if I could set it so that if i could add play counts without having to listen to a certain amount of seconds or percent, instead adding just based on the song ending.
I'm not sure if I understand, then.  You can always set it to increment at 1 second or something, so that it always increments.  Is that not what you want, either?
Pingaware
Or if only when a song finishes, at 100% every time.
wtkafe
How about the pausing issue? If I pause a song at the beginning for a moment it still adds a play count even if I don't listen to it
