However, I think the top menu item for Add-Ons is misleading. Those sub-items (I assume) will point to those sections of the forum. Users might be confused thinking that they can get Skins, Plug-ins, etc from there. And while technically they can, they'll have to search through the forum to find them. Again, this drop-down is part of the forum and might better be placed under the Forum menu item. Perhaps with all the other sub-forums. Or just leave "forums" as is and eliminate the reference to Add-Ons.
I agree with phred, this makes sense.
Fact is, it is probably confusing to some newbies that we have both a website, a forum, and a wiki.
To make that as clear as possible I feel also it would be best to have separate top menu's for forum and wikibee (yep, I am throwing in a new name suggestion for 'wikia' for free ;-)
Then both the 'forum', and the 'wikibee' menu could have their own applicable entries for skins, faq's, downloads, etc.
Of course that's not ideal either, it might confuse new users a bit where to go, but at least it would represent the factual situation as it is. After all the fact just is that we do have some overlaps between the website, forum and wiki.
Thinking this through, maybe it would be good to have an entry called something like: "where to go from here?", briefly explaining the differences between, and features of the website vs. the wiki, vs. the forum.
the whole point of having both wikia and forum is confusing at best. and i DON'T LIKE WIKIA
the main reason wikia is used for having all the skin plugin info in one place, then they link to forum, also is confusing.
the user might (i did) wonder, where could they actually do the download? (or precisely, where is the BIG BUTTON SAY DOWNLOAD?)
wikia SHOULD NOT be using for download links, it should be mainly for FAQ, HOW TO DO's
i am actually thinking about, creating a CMS just for managing PLUGINS and SKINS and others. you won't need any extra account if you sign up with the forum account, you are good to go(only moderator and admin for now),
there would be a central page for getting all the addons, there will be a download button, description, which musicbee version it will work on, os requirement, known bugs, screenshot and a link to the support forum.
so do you guys like the idea?
