Author Topic: Clear lyrics in bulk  (Read 3887 times)
dgbx
Hello,
It would be nice to have the ability to clear the lyrics from a selected set of files.  The reason for this is when other less friendly auto tagging software leaves behind unwanted "Lyrics not found" type messages, thereby filling up the lyrics tag with unwanted text.  In my case, there is also a time stamp which makes search and replace problematic.  After sorting on the Lyrics column of the media library view, it would be easy to select the affected files, and with a choice in the context menu (maybe?), clear the lyrics completely.
Hope you consider it.  Love the software overall!
Dave
foxj
To clear the lyrics / other tags in multiple tracks (in bulk) at once
Select all the tracks you want to change
edit (Shift-Enter)
select the lyrics tab
put a check in the lyrics box
clear any text that may be in the text box
click save
