Author Topic: Foldername out of Playlist  (Read 2278 times)
iampowder
I want to copy some playlists to a SD-Card and create a folder out of the name of the playlist.
For that I have set the storage path for music files to "<Playlist>\<Disc-Track#> - <Title>"
But if songs are in more than one playlist, MusicBee creates multiple folders with "playlist1";playlist2;... for these songs
How is it possible to create one folder per playlist with all songs in it? (also if some songs are several times on the card)
Thanks, Hannes
Edit > Preferences > Devices > Configure > Settings > Playlist storage > uncheck "create a sub-folder for each playlist and its tracks"
iampowder
Thanks phred for your super fast answer, but this checkbox is unchecked   :-\
-Hannes
Actually, I think you want to tick it, not untick it.  Then you will get one folder per playlist.
iampowder
Errr ... yes.  That's what happens when I reply before I've had my first cup of coffee.  Sorry for the confusion.
