I have found that if I connect my MTP device via USB after MusicBee has started, or if I connect it but do not unlock it until after startup, MusicBee cannot access the device. The device is visible in the tree pane, but the storage is inaccessible. If I connect and unlock the device and then start MusicBee, all is fine.
Is there any way of forcing MusicBee to refresh its connection to an MTP device?
Thanks, Doc.
