Hey guys,
I use MusicBee for a short period of time now on my Windows 10 PC.
Because I prefer it this way, I mostly get into my (normal) Explorer and start the music from there. By drag&drop or better by marking them and then press the play button in the menu bar above (in explorer).
This works fine if I choose a small amount of tracks, like 10. But if I try to start a larger amount (e.g. 40 songs) it does start windows media player. So I deactivated wmp, but now it does nothing. All my mediatypes are linked to MusicBee.
I hope someone has an idea to fix this. Btw. d&d does nothing. If something unintelligible I will try to describe it better. Also if this problem was solved somewhere else please link it to me, I did not find something useful with help of the searchfunction and google.
Thank you for your time!
